Forums >> Revit Building >> Technical Support >> Mullion Array gone Arry
I've been piddling with this problem all day. If someone could take a look at this family and let me know what is going on, that would be greatly appreciated.
Essentially when I change the height of the window, the mullion unlocks itself from the sill height plane and steps down. This only happens when 'No. of Mullions' is >2.
Thanks for any help you can give.
-Carl
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
22 Posts No Rating |
I just redid the dimension lines. Set the sill height first, then set the o/a height. then reset the parameters
For as nice of a program Revit is.. sometimes it has some of the strangest quirks...
Thanks jron.
Correction,
Reseting the Height and Default Sill Height parameters only fixed the problem within family editor. For some reason when this 'fixed' family gets put back into the project, it begins misbehaving again (and I did over ride existing parameters).
Any other suggestions would be greatly appreciated.
TIA,
Read my tutorial... on my blog
Edit the nest mullion family.
Goto an elevation
Select the bottom reference plane that overlays the reference level.
Go to its properties
Note that its set to "Not a reference"
Change it to reference bottom and name it bottom.
Save and reload into the project.
Unconstrain the elevational settings of the mullion and then reconstrain them.
HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
Thanks Chris,
I thought it would noteworthy to mention that while chaging the ref. plane to 'Bottom' didn't not fix the problem by itself, I did notice that the last/second element in the array was not locking properly to the plane I wanted it to lock to. Reseting that lock did fix teh problem.
Thanks for everyone's help!
Is Solution to Creating a Parametric Polar Array? |
Tue, Oct 22, 2013 at 8:40:07 PM
How to nest a mullion array family into a window sash |
Mon, Nov 28, 2016 at 12:30:50 PM
array |
Mon, Feb 26, 2007 at 3:09:20 PM
mullion ang transom not fitting well [ 1 2 ] |
Wed, Oct 9, 2013 at 11:42:11 PM
23
Curtain Mullion eats into vert mullion |
Thu, Jan 22, 2015 at 4:49:09 PM
Members: | 2100216 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
