62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> 9.0 or 9.1?
Ok...so from reading everyones posts there appears to be obvious problems with 9.1 that Autodesk needs to address. So what does everyone recommend, should my firm upgrade to 9.1 or should we hold off and stick with 9.0 for now?
It seems like all of the discussion with 9.1 addresses the problems with the program, has anyone been using 9.1 over a network and not encountered any problems at all?
Adam
I have uded it with no problems over my network.
my suggestion is to use it, if its not going to work you should know quickly and then if ther are problems dont use it and go back to 9.0
also its good practice to start and finish a project in the same version of revit. i try to never upgrade my projects and with this release 9.1 i think this is especially important.
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
