53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> UNRECOVERABLE ERROR!!!
24 Posts No Rating |
I wish you couk help me in a serious problem I have.
I was working on a project last night. All was right yesterday. I finished,close the program(REvit 8.1) and turn off the computer.
When I started my job today, and tried to open the archive I was working on, the program displayed the message: " An unrecoverabe problem occourred..." and the program shuts down. I tried several times, with the original archive and the backup copies and the same happens. Then I tried to audit the file, and it displayed the following message: "Data in files need to be manually upgraded..."
What do I do? Do you think I've lost the file?
Please help me...
Thanks.
Ivan
this is what autodesks advice is to this problem
but a clien t of mine had this problem and he lost his project, as it was unrecoverable, sorry for not having better news for you. hope you do get it working.
Error: Data in file needs to be manually upgraded
Published date: 2006-09-09
Applies to:
AutodeskĀ® RevitĀ® Building 9
Issue
When you tried to open a project, you received the following error message:
Data in file <name of the project> needs to be manually upgraded.
Please contact your Autodesk Revit service provider.
Solution
If you receive this message, you should contact your authorized Autodesk reseller for technical support. If you are a subscription customer, you can create a Support Request by following this link: http://pointa.autodesk.com/local/enu/portal/signinSubAware.jsp
Be sure to provide the following information when requesting technical support:
Version number and build of Revit currently being used for the project.
Version number of Revit used to originally create the project, if this project has been upgraded to a new version.
Identify whether or not that the project has worksharing enabled.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
http://www.revitcity.com/forums.php?action=viewthread&thread_id=3742
Unrecoverable Error - Decal |
Tue, Dec 6, 2005 at 3:59:29 PM
Revit 2008 - Unrecoverable Error when Opening Program |
Mon, Mar 24, 2008 at 11:14:57 PM
IFC Export - Unrecoverable Error - Aborted |
Wed, Feb 26, 2014 at 8:15:09 AM
uNRECOVERABLE ERROR WHILE PUBLISHING .DWF SET |
Tue, Feb 13, 2007 at 1:53:26 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:33 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
