86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> walls with furring
Sat, Sep 30, 2006 at 1:14:49 PM | walls with furring
gdoorn
1 Stars: 1 Votes
if you have say a mtl stud and gyp furring assembly on a concrete wall, what is the best way to terminate the furring at 6" above the ceiling level? the methods i can think of are: 1. doing 2 independent walls but stacking them - i dont like this idea 2. doing a stacked wall - i dont fully understand how these work 3. doing a reveal sweep on the furring within the wall assembly itself. - i have tried it this way, but for some reason where i have windows the sweep doesnt apply. any advice or opinions?
Sat, Sep 30, 2006 at 1:54:29 PM | RE: walls with furring
dduarte
dduarte Avatar
3 Stars: 2 Votes
Go to the walls Properties... Edit/ New... Edit Structure... and Preview in section. Select the Modify button and unlock the furring layers from the top of wall (see attached image). This is one way to do it.
David
Sat, Sep 30, 2006 at 2:00:39 PM | RE: walls with furring
dduarte
dduarte Avatar
3 Stars: 2 Votes
You can also go to Tools... Edit Cut Profile... Edit by Face... select the layer you want to terminate and sketch a cutline where you want the layer to terminate (see attached image)
David
Cleaning up Chase Walls & Furring walls
Tue, Jun 14, 2005 at 3:49:07 PM
Furring wall type linework
Fri, Jan 13, 2006 at 9:53:32 AM
Furring on Existing Wall
Fri, Jan 13, 2006 at 3:04:49 PM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
Revit 2010 incorporating structural elements into architectural model
Mon, Nov 23, 2009 at 11:22:39 AM
Page generation time: 15.9714
