106 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Linking mech. Revit Systems into revit arch. title sheet
Fri, Sep 29, 2006 at 4:21:06 PM | Linking mech. Revit Systems into revit arch. title sheet
tomkriegshauser
Can you link mechanical Revit Systems sheet numbers and titles into the architectural title sheet - or - can you link the architectural sheet numbers and titles into Revit Systems based title sheet?
Fri, Sep 29, 2006 at 10:59:11 PM | RE: Linking mech. Revit Systems into revit arch. title sheet
dduarte
dduarte Avatar
3 Stars: 2 Votes
When you're in the View Properties of your Drawing List/Schedule go to the Fields Tab and check the option that says "include elements in linked files." I haven't tried it with a Revit Systems linked file, but it shouldn't be a problem. Post edited on 2006-09-29 23:22:45
David
Mon, Oct 30, 2006 at 7:56:31 AM | Linking mech. Revit Systems into revit arch. title sheet
JCombs
Is there a way to link only the sheet information?  It is impracticle to link an entire project only for the sheet information.
RevitCity:  I really had to search for Submit button!!!
Jason Combs, PE
Woolpert, Inc.
Mon, Oct 30, 2006 at 10:28:08 PM | Linking mech. Revit Systems into revit arch. title sheet
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
When you link in another Revit project you can turn off any user created worksets in that project.  If you turn off all of the user created worksets that should accomplish what you're looking for.
Hiroshi Jacobs
Arch and stuct linked files are showing through Mech obejects in sections
Thu, Jun 16, 2011 at 8:02:44 AM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:27 AM
LINKING REVIT 9.1 FILE to a revit systems 1
Sat, Dec 2, 2006 at 4:36:16 PM
Linking CAD into Revit Arch 13
Thu, Jun 20, 2013 at 12:09:00 PM
Is there anything Revit Architecture can do that MEP can't?
Fri, Apr 17, 2009 at 5:10:44 PM
Page generation time: 2.3941
