95 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Level 2D/3D extent control
Fri, Sep 29, 2006 at 4:46:43 AM | Level 2D/3D extent control
DaveF
Hi Is there a quick way to change the 3d icon to 2d for all the levels in an elevation view? (or even better in all views). I have a model with non parallel grid lines so I don't wnat the levels to amend in all elevation when I stretch the level. Also I had to rotate the grid & therefore had to realign the elevations. The 2d symbols reset to 3d. Very annoying. How can I prevent this from happening? Cheers Dave F.
Fri, Sep 29, 2006 at 11:18:53 PM | RE: Level 2D/3D extent control
dduarte
dduarte Avatar
3 Stars: 2 Votes
Change one of your datums to 2D and Propagate Extents to change the properties of that datum in all views in which the datum is visible to 2D. Post edited on 2006-09-29 23:22:27
David
Grids - Maximise 2D extent?
Tue, Feb 5, 2008 at 6:39:49 PM
Control elevation view - level line
Sun, Apr 2, 2006 at 10:26:30 PM
Extent of Area reinforcement symbol
Wed, Sep 23, 2009 at 6:23:44 PM
Hiding pieces of a Level Line 2008
Mon, Jan 28, 2008 at 10:54:50 AM
Level Elevation
Tue, Jul 7, 2009 at 2:39:02 PM
11
Page generation time: 0.8607
