50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> Bridges
1 Posts No Rating |
We're a company that does timber and steel bridges. I've been looking at Revit Structural to see if that would be the recommended software. I generate the drawings in 2D now and then work up a material list from the drawings. From what I've read it would generate a material list from the 3D model. You can also make a set of plans from your 3D model. What do you guys think, is this feasible?
Thanks
31 Posts No Rating |
of course
revit would be perfect
I haven't had any experience with Revit Structural myself, but if you checkout the www.augi.com Revit structural forums i'm sure their will be some helpful information there from people using it for just that purpose.
HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
there is info on autodesk disscusion groups
heres the link
http://discussion.autodesk.com/thread.jspa?threadID=414617
here is the section in the form you want to browse to.
Re: Revit structure for bridges
you can actually design bridges as far as geometry is concerned. and you can get drawings. The parametric technology is just perfect for this type of design. There are also terrain modeling and phases for segmental construction in the product.
I have attached some examples in a Word document
As far as structural analysis is concerned you would need to use RISA or Robot and then adjust the analytical model that may be incomplete for moving loads.
We do not provide (yet) tutorials but our implementation team could help you out
using revit to design bridges |
Thu, Jun 16, 2005 at 4:50:33 PM
Bridges in Revit extentions |
Thu, Apr 23, 2009 at 1:16:07 AM
Arch bridges.. HELP please.. |
Fri, Mar 27, 2015 at 11:22:29 AM
New to Revit |
Sat, Apr 11, 2009 at 5:50:34 PM
Tensile cables??? ( metal ) |
Fri, Sep 3, 2004 at 12:56:42 PM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
