112 Users Online (111 Members):
Forums >> Revit Building >> Technical Support >> Window tags not showing
I am having difficulties in having my transom window tags showing on my floor plans. I understand that generally that Revit will not show the tags outside of the view rang. Is there a way to work around this? Is there a trick to get this to work the way I want it to?
Try temporarily moving the cut plane up o cut through the transom windows, then tag them and move cut plane back to normal. The tags should stick.
You of course could also use a "plan region" and adjust the cut plane just for that area which should allow tagging as well.
HTH
Tom
It did not work.
My view range settings were Top: 7'-6" and Cut Plane: 4'-0"
My transom's sill height is 8'-0" and head height is 9'-6"
Therefore: I changed the Top: 9'-0" and CUt Plane: 9'-0"
I then tagged them.
When I change the cut plane to 4'-0", they show up. However the overlapping transoms to the windows below cancel each other out. (The widows don't show). So when I change the Top back to 7'-6" the tags dissapear.
I then edited my Transom Window and ajusted my visibilty to not show in plan. When I reloaded this, it now works.
Thanks for your help. It really did help. I just wanted to share my conclusion and solution with everyone.
Window tags & showing window #(Mark) on plan |
Thu, Nov 3, 2005 at 9:46:11 AM
Window tags disappear when I copy the window... |
Fri, Jun 14, 2013 at 2:19:23 PM
Window Tags not working |
Fri, Sep 24, 2010 at 7:30:45 PM
window tags in elevation |
Tue, Feb 13, 2007 at 12:51:56 PM
Elevation Tags not showing when I cut a Section View |
Mon, Oct 20, 2014 at 2:43:05 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
