83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit Systems duct connections
Thu, Sep 28, 2006 at 12:05:15 PM | Revit Systems duct connections
tomkriegshauser
How do I tap a round duct to the underside of a rectangle duct using the Autodesk Revit Systems software
Thu, Jun 28, 2007 at 2:11:06 PM | Revit Systems duct connections
jtoutant
See the Mechanical Tutorial, Completing the Supply Air Systems, Placing AC Units.  This is a tap off the side, not the bottom, but you should be able to follow those steps (p. 10Shadey in an elevation view and get it done.  Simply select Round Duct with the Diameter that you want, start the duct at the centerline snap of the rectangular duct, and extend to the circular duct you're connecting to.
 Jay
Thu, Jun 28, 2007 at 2:13:44 PM | Revit Systems duct connections
jtoutant
See above, that's page 108.
Thu, Jun 11, 2009 at 9:32:41 AM | Revit Systems duct connections
lookforsaju
Try using the section view to make the connection. Also you could get better results if you have the tap connection type set to standard.
Duct Systems.
Mon, Aug 5, 2013 at 7:48:16 AM
Revit MEP 2010 Duct System Colors
Tue, May 18, 2010 at 6:04:49 PM
Rectangular Flex Duct
Tue, Jan 21, 2014 at 2:45:16 PM
Multiple Connections One Family
Sun, Nov 7, 2010 at 7:58:51 PM
Duct System problem
Fri, Jan 11, 2013 at 8:05:19 AM
Page generation time: 2.6145
