45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> doors opened in 3D views
Wed, Sep 27, 2006 at 3:22:57 AM | doors opened in 3D views
Marian
I'm having a problem with doors. When I place doors for the need of floor plans it's good that they are presented as opened. This is obvious. But how on earth can make the same doors look as closed in a 3D view. It looks realy stupid when you have a nice perspective 3D view and all the doors are opened. Please help. Marian
Wed, Sep 27, 2006 at 9:01:58 AM | RE: doors opened in 3D views
latemore
latemore Avatar
3 Stars: 2 Votes
hi marian this is a family issue. sounds like you are using a door family with the door's visibility set to be visible as open in most views. i suggest you use another family, which has symbolic plan view lines with door open, and the door 'shut' and visible in 3d, elev only. try something from the standard library. hope that helps.
Wed, Sep 27, 2006 at 9:20:30 AM | RE: doors opened in 3D views
Marian
Thanks, Marian
Recently opened views
Sat, Mar 31, 2012 at 10:04:10 AM
How to show fully opened doors in 3D?
Tue, Jan 22, 2013 at 11:25:57 AM
Problems Changing Colours Of Doors!
Wed, Jul 1, 2009 at 3:24:19 PM
Cannot load any doors into project
Mon, Oct 24, 2011 at 11:22:19 AM
Windows and doors not showing up in walls
Mon, Nov 8, 2010 at 3:24:06 PM
Page generation time: 0.5893
