Forums >> Revit Building >> Technical Support >> elevation swing conflict.
46 Posts No Rating |
elevation swings are missdirected.look at the door.
It looks like to me that their is not a problem if you look at the floor plan the window is on one side and the elevation the window is on the other side. Same w/ the door.
in Turkey we draw from hinges to the handle..i mean two "swing line" connects where the door handle is..
5 Posts No Rating |
As an apprentice many, many moons ago, I also was taught to draw the swing lines from the hinges to the handle. If necessary, open the door families and change the front and rear elevations to match.
----------------------------------- Cheers
DTH
(I Plan to Live Forever - So Far So Good) |
33 Posts No Rating |
So, I'm wondering.
Why is it when you click on the two pictures above you're redirected to an ITT ad.
And from there if you do as it suggest and click on the image to see it at it's original size, you're redirected again, not to another picture, but another complete ad.?.
...just wondering.
Poppy
Advice on showing door swing in elevation |
Tue, Dec 14, 2010 at 7:05:11 AM
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ] |
Tue, May 12, 2020 at 2:41:53 PM
16
Door Swing Question |
Mon, Oct 22, 2012 at 3:51:33 PM
12
swing lines on casework doors |
Fri, Jul 20, 2018 at 10:53:49 AM
Need swing lines for casement window |
Tue, Jun 9, 2015 at 6:06:48 PM
Members: | 2102386 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
