Forums >> Revit Building >> Technical Support >> import/export line weight setting - is it possible between two projects?
28 Posts No Rating |
and another one - is it possible to trim several lines by another line in one command like trim does in Autocad?
Thanks
On you trim command, tick multiple in the options bar. You still need to pick the lines one by one, but you'll only need to click the cut/extension line once.
HTH.
Thanks but triming that way is not what you expect from a software by autocad. It is like very basic command that should be there.
16 Posts No Rating |
tried to report that this post title is mis-leading (not so much offensive). The subject line has nothing to do with the content
It appears it was two questions but no one answered the subject question. That is my question. Is there a way to export/import line weight settings between different projects and families?
It's got to be happy hour somewhere |
see... http://www.revitcity.com/forums.php?action=viewthread&thread_id=9908
Thank you!
