165 Users Online (164 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> visibility
Sun, Sep 24, 2006 at 6:21:50 AM | visibility
seedy
I have a site plan, with a vehicle and property lines. I wish to turn off the visibilty of the the vehicle but the property lines go too ( as site components) Is there a way of making individual objects visible? I tried temporay hide which is ok... but it still plots....no good thanks for any help
Sun, Sep 24, 2006 at 1:31:12 PM | RE: visibility
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You can edit the vehicle families and put them on a sub-category of site and then only turn that sub-category off in the visibility settings... or you can use worksets. With worksets you can put the vehicles on their own workset then turn that workset off. Or...you can use view filters to control visibility of objects based on a parameter you define.
Hiroshi Jacobs
The Catholic University of America
Sun, Sep 24, 2006 at 5:06:22 PM | RE: visibility
DTS
It also depends on how the vehicle's built. If it is built purely from Revit by solids then you can specify the subcategories, if the family is created by importing a 3d autocad block then you can go to visibility graphics, under "imported categories" and turn of the imported 3D block.
Sun, Sep 24, 2006 at 11:14:37 PM | RE: visibility
seedy
thanks for the advice ....ill have a go
Mon, Sep 25, 2006 at 3:17:36 AM | RE: visibility
silverangle
silverangle Avatar
all the above plus you could set up a design option to control whether or not the car is included in the views you create..........if it was an import (which i hope it is) the easiest way would be through the vis graphics as above. Regards John J
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY
Mon, Aug 7, 2006 at 5:36:38 PM
Symbolic Element Visibility
Tue, Feb 4, 2020 at 6:42:28 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:39 AM
Page generation time: 0.3754
