Forums >> Revit Building >> Technical Support >> Same Wall, Different Problem
33 Posts No Rating |
When I created this wall style, I had no clue it would give me so much trouble. Now, I'm having problem getting rid of seams when windows or doors are placed in this wall. I've attached the wall and window if anyone has time to look at it. Any suggestions would be so greatly appreciated! Please, help, if you have any suggestions. I have to submit the first of the week, and I don't want to have the sketch everything in to clean it up.
Thanks in advance,
Poppy
11 Posts No Rating |
TRy this solution
This is host wall sweep.
If you don't like the section it cuts then you can create a detail component to cover it up. At least it fixes all your seams.
Thank you, thank you!
Easy fix right in front of me.
Sorry about the fuss on not getting a response.
I think I see why, I need to come up with more challenging problems.
None the less, I am grateful you (DTS) took the time to address this one!
Thanks,
Poppy
Wall crossing problem |
Thu, Apr 11, 2013 at 5:37:44 PM
Problem with an angled curtain wall |
Mon, Jun 18, 2012 at 1:39:37 PM
11
Horizontal wall |
Tue, Mar 20, 2018 at 2:48:21 PM
Problem with wall connections |
Thu, May 5, 2011 at 4:12:35 PM
Wall Cleanup Problem |
Thu, Dec 4, 2008 at 5:39:14 AM
Members: | 2104101 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
