57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Can't load more than a family at a time :(
27 Posts No Rating |
I've been recently trying to explore Revit 6.1 (I'm a Revit newbie, I must add), and while going through the tutorials it says that I can load more than one family at a time into my project, but I haven't been able to do so! I press down Ctrl and leave it pressed, try to select more than one door, but I can't seem to select more than one at a time
What's happening here? Am I doing something wrong?
It sounds like your using the load button that appears when for instance you select doors.
Instead, go to your file pull down menu and choose load family. You should be able to load multiple families here...
Yup, it was my mistake. hehe
Your suggestion worked! Thanks ![Smile](/images/smiles/smile.gif)
the load in family not working |
Fri, Aug 19, 2016 at 1:01:12 AM
Family Won't Load |
Mon, Apr 11, 2011 at 6:34:13 PM
Not able to import families through load family..no error msg.jury tomo!! |
Thu, Jun 6, 2013 at 9:24:12 PM
Families won't load? |
Tue, Sep 2, 2008 at 1:17:06 PM
Cannot load family |
Mon, Apr 18, 2011 at 5:22:02 PM
Members: | 2022277 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
