66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Redundant Rooms
Hello
How do I get rid of "redundant rooms?" do I need to create a room boundary around the entire perimeter of a room?
Thanks
51 Posts No Rating |
In my experience, Revit always gives you a warning when a redundant room is created - primarily by the deletion of a common wall. I usually cancel the delete command, erase the room first with its associated room tag, and then delete the wall. As for how to delete one that was already created, I think you just have to pan around the area of the room until you find the room "X" of the redundant room and delete it. Don't forget that they also appear any time you initiate the ROOM tool (they all turn blue). That will also give you the redundant room's location.
HTH
If you create a room schedule with areas shown, all the redundant rooms will show up as "redundant room" in the Area field.
In the schedule you can then simply highlite the row of the offending room and hit the delete button.
Tom
Thanks for your help!
rooms?? |
Tue, Oct 29, 2013 at 11:10:18 AM
Deleting Rooms from Schedules |
Tue, May 8, 2012 at 8:30:32 PM
Rooms within Rooms? I think... |
Tue, Nov 9, 2010 at 11:45:56 AM
Programming spaces/rooms in Revit |
Fri, Jun 21, 2013 at 9:20:34 AM
REVIT 15: Can not place rooms on upper and lower levels.... |
Tue, Feb 12, 2019 at 4:58:36 PM
Members: | 2016947 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
