78 Users Online (76 Members):
Forums >> Community >> The Studio >> White ceiling paint (and other white objects) Rendering "GREY"
5 Posts No Rating |
when i render a scene the ceiling paint turns out grey. I am using downlighters. should i use radiosioty????
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Radiosity might help, but depends on the size of your scene.
Since Revit/Accurender lacks any kind of "global illumination" I usually place a few "studio lights" in my scene to cast additional light up toward the ceiling and other objects that are too grey.
You can find the "studio lights" under lighting in the Revit library. They are essentially "orbs" of light not tied to a real light fixture. Place them at the mid point between your floor and ceiling for the best effect and not too close to walls or other objects so as not to get hot spots in your rendering.
HTH
Tom
90 Posts No Rating |
I am not use studio light, define materal for ceiling with a little amouth ilumination but be carefuly not to much
There is a setting in the materials editor for self luminance, adjust this approx 0.100.
![2 Stars: 3 Votes](/images/stars_2.gif) |
Wow, this works? I suppose I've had the same problem with grey ceilings myself - adding studio lights is just so tedious!
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
"Wow, this works? I suppose I've had the same problem with grey ceilings myself - adding studio lights is just so tedious!"
Actually, just check the "glow" box in you Gyp Board material, and they will be whiter. But, in actuality, look at the ceiling where you sit at currently...it's a shade of gray, isn't it? Mine is....
Post edited on 2006-09-27 23:53:21
2008 Revit_ White walls rendering grey |
Thu, Jul 10, 2008 at 11:50:25 AM
White walls are dark grey when rendered? |
Wed, Aug 10, 2005 at 10:57:54 PM
2009 SHADED VIEW CAN NOT FIND "GLOW" TO MAKE CEILING LIGHTER IN COLOUR |
Wed, Jan 28, 2009 at 6:04:37 PM
"Paint" and In-Place Component Material Bug? |
Thu, Apr 14, 2016 at 2:47:43 PM
Window view on floor plan (grey instead of white) |
Tue, Oct 15, 2013 at 10:39:44 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
