Forums >> Revit Building >> Technical Support >> Insert Revit plan into Word
Is there a way to take a plan from Revit to insert into MS Word with high quality? I've tried tiff, .jpg, targa. Tried thru file>export. All come out with resolution loss especially on text. A .pdf is very crisp, but cant be used in a word document. Also tried to import a .dwg and word says "an error occured", tried several times in 2004 and 2000 autocad format exports.
try
file
export
then choose the plan you want
choose Zoom to option
choose zoom size
choose jpeg lossless
THEN CHOOSE RASTER IAMGE QUALITY
CHOOSE 600 DPI.
I did exactly that, with various zoom sizes from 15% tp 100% They all yield as shown in attachement detail area a fuzzy image for non-recatlinear parts
if you want to insert it into MS Word as a raster image you will get better quality if you print to pdf first and open the pdf in Photoshop and save it to a raster file format such as jpg.
if you want it as a vector file in Word, then print to dwg first and export out of Autocad as a WMF with the WMFOUT command and then insert the wmf into word.
HTH
Post edited on 2006-09-18 14:46:08
Thank you Coreed! The the WMFOUT routine works perfectly. I note that the autocad file layer color and linetype settings must be exactly as you want them to appear in the word document and all is well.
Importing MS Word (or other text) into Revit |
Thu, Jul 31, 2014 at 8:48:36 AM
11
Can't figure out how to insert Recessed Can lighting into ceiling plan |
Mon, Aug 16, 2010 at 12:50:06 PM
How to insert a window in a round roof |
Fri, Dec 4, 2009 at 6:21:33 AM
PROFILE INSERT VISIBILITY Revit 2015 |
Mon, Jul 20, 2015 at 9:41:27 AM
importing table from word |
Wed, Jul 3, 2013 at 10:20:16 AM
Members: | 2098675 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
