38 Users Online (37 Members):
Forums >> Revit Building >> Tips & Tricks >> how to add new aq. render materials
1 Posts No Rating |
is that jpeg files or it is scaned files?
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
well, seeing as scanned files can be jpg files.. the answer is yes.
Some of them are photos of actual materials. Many of them also have transparency maps and such attached to them.
So if you scan an image of a material in, yes, you can use it as a material. is this what you are asking?
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
![4.5 Stars: 7 Votes](/images/stars_4.5.gif) |
Using maps is fairly easy, but how do I make a new material library. Is that a .mlib file. I have AutoCAD 2007 and it comes with hundreds of materials. Is there a way to make a revit material library with these materials in it, or should I just continue to apply them as maps?
ArchWestCY
![4 Stars: 13 Votes](/images/stars_4.gif) |
It appears manual unfortunately. I'd like to do the same. Under setting>materials click the arrow beside AccuRender then click the material menu and click new. Or you can use the user library when you make new materials to store in. I don't know of any batch program that will do this manually.
Render materials lost link |
Mon, Nov 30, 2009 at 9:36:59 AM
Adding materials into Revit's materials files |
Thu, Jul 22, 2010 at 1:54:48 PM
Materials not showing in render |
Wed, Jul 6, 2011 at 1:14:38 PM
Adding new render material |
Wed, Nov 2, 2011 at 10:39:45 PM
Can't get any materials to render |
Tue, Jun 2, 2009 at 9:49:29 AM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
