118 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> titleblocks
Sat, Sep 16, 2006 at 1:20:21 AM | titleblocks
vector23
vector23 Avatar
2 Stars: 16 Votes
when i create a new titleblock there are three choices for line weights- thin, medium, and wide.. however i want a much wider line on my titleblock.. how can i do this?
Sat, Sep 16, 2006 at 2:53:27 AM | RE: titleblocks
Molonesh
Change the thickness of the wide line in the"line styles" setting, and create there new line styles as much as you need. I have created a line style for every pen weight - so i know what to use at drafting to get a certain weight.
Sat, Sep 16, 2006 at 5:00:36 PM | RE: titleblocks
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This can be done quite easily. The confusing thing is in families linestyles are not controlled in the linestyle settings, they are controlled in the object styles. So if you create a new objectstyle in your object style settings and set the appropriate linetype and weight then new linestyles will be available for use of the same name. I wouldn't suggest changing the wide lines in the family, as typically this object style is already set in projects and when you load it into a project the amended lineweight will not be updated, so you'd have to update your template file with thi. HTH.
TitleBlocks
Fri, Dec 8, 2006 at 8:08:03 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:34 PM
Labels in Titleblocks?
Mon, Nov 10, 2008 at 3:30:02 PM
Titleblocks
Mon, Mar 17, 2008 at 3:03:11 PM
Multiline text on Titleblocks
Sun, Oct 5, 2008 at 8:17:14 PM
Page generation time: 0.9698
