57 Users Online (56 Members):
Forums >> Community >> The Studio >> Roofs
2 Posts No Rating |
I have a terrace of existing houses on a sloping site where the roofs are a continuous run rather than being stepped. Is there a way of showing this with this. The roofs are traditional with a ridge running down the centre at a pitch of 30 degrees and the street is sloping down left to right with a drop of 1.5m over 25m.
I would be grateful if anybody out there can help as it seems to be a recurring situation.
"Is there a way of showing this with this."
I'll try to help the best I can, but I don't quite understand what exactly you are looking for
23 Posts No Rating |
Nor could I. Please attach a file.
Instead of making the roof the convential method, have you tried creating a new component, selecting roof and do it by solid extrusion? You will need to set up a reference plane first
Hope it might be useful
Regards
Will
2 Posts No Rating |
I have attached a simple example of what I am trying to achieve. You will notice that the pitched roof created just runs at a set level. What I want to achieve is the roof fascia and ridge line to be parallel with the top of the wall. One of my colleagues is looking into the possibility of solid extrusion to see if he has any joy.
3 Posts No Rating |
Hello everybody, first i want to excuse me for my english but it`s not my native language. I`m not shure if it is the same problem but i have to do a strange roof with profile cut from the thickness of the roof`s overhang I am attaching a dwg this is a section. i am not shure if you understood from my description so i marked the location on the drawing with white cyrcles.
Create a "void" in "model-in-place" in the family "Roof" and use the "Cut Geometry" tool to cut that portion you don't want.....
3 Posts No Rating |
Thanks it worked
joining roofs |
Mon, Jan 9, 2006 at 1:20:09 PM
Intersecting roofs |
Mon, Oct 16, 2006 at 8:28:41 AM
Problems joining roofs |
Fri, Apr 16, 2010 at 10:52:16 AM
Revit 2008 Multiple Roofs on Same level? |
Tue, Jul 24, 2007 at 9:05:38 AM
12
Roof problems with 2 gable roofs with different pitches. |
Sat, May 1, 2010 at 1:27:57 PM
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
