56 Users Online (54 Members):
Forums >> Community >> The Studio >> A toposurface problem?
23 Posts No Rating |
Hi,
When creating a toposurface by importing a Autocad drawing, if the countours in the dwg file are relative to the sea-level like 97.5 meters, etc, the toposurface created by revit has a huge mass of earth below the surface. how do i reduce the depth of this mass without redoing the dwg in autocad. till now i have resized the crop region to get the desired depth.
![3 Stars: 1 Votes](/images/stars_3.gif) |
check your levels too see if they are referencing a level well below your topo surface
No, the levels do not reference any other levels.
![sjs Avatar](user_avatar/1503.jpg)
![3.5 Stars: 10 Votes](/images/stars_3.5.gif) |
Settings -> Site Settings -> Elevation of poche base
Hi,
Solved the Problem- In the AutoCAD drawing I had drawn the property extents - and this polyline had an elevation of 0.0!! So revit created a toposurface with one contuor as 0.0 and all others at their specified elevations. So the huge mass of earth below the toposurface.
Humans err, the software doesn't!!
Thanks.
toposurface problem!!! |
Fri, Nov 5, 2010 at 7:40:03 AM
Toposurface problem |
Thu, Feb 25, 2010 at 4:37:33 PM
Toposurface |
Tue, May 11, 2010 at 9:04:45 AM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
