109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> .dwg export layers
44 Posts No Rating |
Hi,
You know what really irritates the h_ll out of me. The way lines types all default the A-DETL layer. If I saw a need to give that line a distinct layer, it should default to the same name. I know I can manually edit these, but it is a PITA. I hope I am just missing a setting so I can be embarrassed instead of being extremely annoyed.
Sam
58 Posts No Rating |
i dont think that can be done...it has to be manually editted...sorry but thats the only way i know.. anyone else has a better option??
Hi Nandini,
Thanks for posting. I should probably mention that I am a big Revit Fan. After a year and a half with not too many gripes. Problem is, I usually notice that I forgot to edit a few added layers after I have exported and I am well on my way. After a year and a half of this I finally blew a fuse. I realized, this is just plain stupid!
Thanks for Listening,
Sam
I hear you!
exporting to dwg is a pain in the neck!! why so much trouble from a company that sells the 2 products is beyond me... fair enough, when Autodesk bought Revit, one can expect a period of of getting everything to work, but we are on 9.1 and 10 to be released soon, one would expect a better dwg export without getting lost in the export layers...
dwg export duplicate layers |
Tue, Dec 3, 2013 at 3:29:32 AM
REVIT 2013 - Export DWG Layers Text File Location |
Fri, Aug 3, 2018 at 4:44:52 PM
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:27:59 AM
Export to dwg or dgn. Layers |
Wed, Nov 18, 2009 at 12:04:10 PM
DWG Export Setup for particular layers? |
Wed, Jul 24, 2013 at 3:22:41 PM
Members: | 2042270 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
