129 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Please Help
Wed, Sep 13, 2006 at 3:27:47 PM | Please Help
akccrox
I'm trying to dreaw an octagonal roof (bavarian castle themed) the roof was drawn in cad and looks fine but I can't get revit to handle the three pitch design and have all the edges meet at 15'-6" above the start point althoug I insert the correct piichs to alow the desired hieght. Instead I get somthing that looks more like a multi pitch roof for a mud hut. Does anyone have advice?
Thu, Sep 14, 2006 at 3:44:14 PM | RE: Please Help
ArchWestCY
4.5 Stars: 7 Votes
Try drawing one section of the roof. Then array it around to the other sides. Also instead of using the "defines slope" check box, try using the slope arrow. You may even need to draw each pitch seperatly and then join roof before arraying it around. ArchWestCY
Thu, Sep 14, 2006 at 3:57:08 PM | RE: Please Help
brant
4 Stars: 3 Votes
Akccrox, I think ArchWest has ok suggestions, but those should be last resort. An octagonal roof should be quite easy via footprint. Try making a level for just the roof plate first. Then with a 0'-0" offset from that level for all elements, draw the roof with all the same pitches. Complete the roof, then go back and edit it. This time, change the pitches to what you want. Revit sometimes assumes certain elevation changes depending on the order in which you draw. So it's good to get a clean start.
Thu, Nov 16, 2006 at 8:39:33 AM | Please Help
akccrox
thanks for the help guys.
Page generation time: 5.0409
