81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Reset Linework?
15 Posts No Rating |
I was wondering if there was a command or procedure to allow you to reset all of the linework you have done in a particular view. Anyone have an idea?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
no you can't as far as I know.
you could pick a line, right click and select all instances, and than change properties.
Quickest way would be to recreate the view...
Alternatively you could re-use the linework tool and set it by category then pick all your linework... It will only select lines that have been overridden.
HTH.
Regards,
Chris.
Can you save linework? |
Tue, Aug 12, 2008 at 7:37:07 PM
display order command and reset visibility graphic setting |
Tue, Jul 31, 2007 at 2:51:00 PM
Reset Yes/No parameter in schedules to neutral |
Wed, Feb 1, 2012 at 3:49:55 PM
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations |
Sun, Mar 30, 2008 at 12:30:48 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
