Forums >> Revit Building >> Technical Support >> Solid Sweep Creation
I am trying to create a solid sweep using a kerb profile that follows the gradient of a topography surface. Does anyone know if this is possible to do? I can easily create the sweep horizontally but am unable to make it follow the gradient of the surface!!
Any help would be much appreciated, thanks
you won't be able to pick a path using your topo.
have a look at my tutorial "complex slabs and pathways" might help...
I hope that soon we will have better topo and site tools...
Thanks for that, your tutorial is very useful indeed. Great lateral thinking, I would never have thought of using the roof command to create a kerb shaped fascia, very clever! Hopefully Autodesk will work something out soon to make this operation much easier.
Many thanks
Rob
18 Posts No Rating |
Where can I access these toutorials
look at the top of the screen under Tutorials
HTH
Post edited on 2006-09-13 15:27:56
Solid sweep |
Wed, Jun 3, 2009 at 8:22:42 AM
Solid Sweep and doors? |
Thu, Apr 27, 2006 at 10:59:12 PM
Cutting Solid Sweep? |
Sun, Apr 23, 2006 at 11:03:52 AM
Material surface pattern on a solid sweep? |
Wed, Nov 17, 2010 at 2:48:50 PM
Hatch to solid sweep |
Fri, Mar 30, 2007 at 2:00:20 AM
Members: | 2114903 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
