63 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Distributed Rendering
10 Posts No Rating |
Does anyone know if it's possible to render walkthrough's in Revit using "distribute rendering"?
I know rendering a walkthrough takes a while, but for a walkthrough of 400 frames at 5 fps with a image size of 72 dpi, it's taking 16 hrs. just to get to 17%. The computer I am working on has a single 3.20 GHz processor w/ 1GB of RAM . . . is the distribute rendering possible with Revit? . . . do I need more processor speed?
Good question, I think alot of people would like to know the answer!
And if there are any keen computer programers out there reading this, there is a stack to be made on a small plugin to Revit that will allow users to farm networked computers!
no, not at this time...
you could upgrade your computer to a dual core...
You can set different frame ranges to render on different computers. But that's the best you are going to get. IE: frames 1-100 on one computer, 101-200 on another.
The only issue is you may experience slight lighting differences between each segment, as revit uses the first frame to of the exported sequence to calculate the lighting for the remaining frames.
HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
I know this is an old thread.... In regards to rendered walkthru, can you render a frames in sections (i.e., 1-500 , 501-1000, 1001-1500 and so on) using the same file? (this warns you that it will be a read only) but you I think you can still save the walkthrough file(s). In otherwords, multi-tasking using a single computer. Have you guys tried this procedure and did it worked? Let me know. Thx.
"If you tell the truth, you don't have to remember anything" |
Well... guess what?! It did worked. I used a single computer and open the same file in multiple-Revit Apps. It works great! rather than waiting for the other one to finish...why not run them all together at the same time. Sweet!
Distributed Rendering to Rendering Server |
Thu, Jun 14, 2007 at 2:12:25 PM
3DS MAX using Backburner scan lines problems |
Tue, May 28, 2013 at 5:03:25 PM
Archivision RPC's, Placing and Managing w/in a project. |
Tue, Aug 4, 2009 at 5:02:26 PM
3d Studio Max import/link revit file |
Wed, Mar 20, 2013 at 11:49:21 AM
backburner on all office computer |
Thu, Oct 6, 2011 at 10:28:03 AM
Members: | 2056478 | Objects: | 23071 | Forum Posts: | 152325 | Job Listings: | 3 |
