104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> sloped flat roof - Q2of2
Mon, Sep 11, 2006 at 12:02:16 PM | sloped flat roof - Q2of2
tomkriegshauser
how do i construct a flat roof to meet these criteria: 1. flat roof for retail building constructed of 5" insulation on 1 1/2" metal deck on steel joists 2. roof is square in plan 3. two adjacent roof corners, which are the highest of the four corners, are at the same elevation (t.o. steel is known) 4. third roof corner is at an elevation slightly lower than the two corners listed in #3 above (t.o. steel is known) 5. fourth roof corner, which is the lowest of the four corners, slopes 1/4" per foot from both corners listed in #3 above (t.o. steel is known)
Mon, Sep 11, 2006 at 5:25:30 PM | RE: sloped flat roof - Q2of2
eldados
eldados Avatar
4.5 Stars: 8 Votes
the roof can be compound just like floors, read my tutorial on complex slabs and pathways, hope it will help Smile
Integrator
KarelCAD
SLOPED FLAT ROOF
Sat, May 9, 2009 at 9:09:39 AM
Sloped flat roof
Mon, Jun 18, 2007 at 2:24:42 PM
sloped flat roof - Q1of2
Mon, Sep 11, 2006 at 11:56:11 AM
New Member-flat/sloped roof problems.
Thu, Jul 9, 2009 at 2:43:42 AM
Flat ridge on sloped walls?
Sat, Mar 21, 2009 at 6:14:21 AM
Page generation time: 2.1557
