73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Accurender Materials
Mon, Sep 11, 2006 at 9:54:03 AM | Accurender Materials
wkarabinos
Can someone tell me where i can go to download accurender materials for revit?? I know that you can edit the materials to make new ones but i was just wondering if there is someplace that i can go to download a bunch of them instead of having to invest time in editing the existing materials. And also is their anyplace where i can download more image maps? I was working on a interior rendering and the Acoustical Tile that comes with revit evertime i rendered the scene the ceiling tile appeared to be more gray than it was white. I tried editing the existing 24 x 24 ACT map using Photoshop hoping to create one that was more white and after i edited the existing map it changed the scale of the ceiling grid, so instead of having a 24 x 24 grid the grid appeared to be around 12 x 12 after i rendered. Hopefully someone can lead me in a direction where i can download some more material maps, thanks
Mon, Sep 11, 2006 at 10:49:21 AM | RE: Accurender Materials
kalimeris
I dont know where you can download some materials.If you find some tell me because I'm looking too. But i think the solution for your problem about gray appearence of white objects is to make a custom material from a material of your choise. Save it in "User" library and then right clik on it and select edit. Now to "Main" tab change value 0.000 to 0.500 to "Self Luminance" space. I hope to have a good apearence now
Mon, Sep 11, 2006 at 12:11:18 PM | RE: Accurender Materials
coreed
coreed Avatar
4 Stars: 16 Votes
you can find some materials at the link below http://www.accustudio.com/ HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Sep 15, 2006 at 4:51:07 AM | RE: Accurender Materials
Elmo
3.5 Stars: 4 Votes
You can also make your own materials from Jpg's.All you need to do is map it in your new material. Post edited on 2006-09-15 04:53:07
Adding new materials to accurender library
Thu, Nov 19, 2009 at 5:44:19 AM
ACCURENDER
Mon, Feb 19, 2007 at 3:16:53 PM
Customized Accurender Properties in Linked Files
Wed, Dec 5, 2007 at 1:56:52 AM
Accurender materials not appearing in VIZ
Mon, Jan 21, 2008 at 5:27:45 PM
Materials Wrong when Rendering Families w/ 3d CAD Imports RA2008
Fri, Sep 21, 2007 at 7:45:28 AM
Page generation time: 0.6723
