61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Tag problem
4 Posts No Rating |
I am working on a tag to indicate the area of a green area, as the green area is not enclosed by wall, I can`t use room tag or area tag. Does anyone know how can i make a tag which can tag to a floor and showing the area of it?
thanks
24 Posts No Rating |
Hi,
You could use your room separation tool to draw the boundary of the green area. This will give the Room tag a boundary to calculate. If the Room Separation Lines need to be invisible you can then turn the Room Separation lines off in the visibility settings.
4 Posts No Rating |
Thank you very much~I can make it now
Help. Room Tag Problem |
Wed, Nov 28, 2007 at 8:09:48 AM
Problem with Multi Category tag |
Mon, Apr 3, 2006 at 12:48:41 AM
Tag Display problem [ 1 2 ] |
Wed, Jun 24, 2015 at 9:13:35 AM
15
Keynote Tag defaulting to Category Tag |
Fri, Jul 20, 2018 at 11:20:17 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
