40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> multi level walkthoughs
Sun, Sep 10, 2006 at 9:19:26 PM | multi level walkthoughs
hammer87
hammer87 Avatar
3 Stars: 4 Votes
whats the eaist way to do a multilevel walkthough?
Mon, Sep 11, 2006 at 5:30:51 PM | RE: multi level walkthoughs
eldados
eldados Avatar
4.5 Stars: 8 Votes
you can do it as one walkthrough if you want, you will need to adjust height and angle of each camera point. you could also make a few short walkthroughs and put them together using "movie make" or similar...
Integrator
KarelCAD
Mon, Sep 11, 2006 at 7:59:38 PM | RE: multi level walkthoughs
hammer87
hammer87 Avatar
3 Stars: 4 Votes
so if i went the movie maker route would that be eaiser
Mon, Sep 11, 2006 at 8:30:36 PM | RE: multi level walkthoughs
eldados
eldados Avatar
4.5 Stars: 8 Votes
it's really up to you... you might find rendering smaller portions and putting them together with some fading in and out in movie maker a little easier than trying to define a whole path going up and down...
Integrator
KarelCAD
Tue, Sep 12, 2006 at 8:35:50 AM | RE: multi level walkthoughs
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ya it iwould be easier and proly wont take as long rendering. one walkthough i did took 17 hrs. on low quailty.
Fri, Nov 20, 2009 at 7:18:03 AM | multi level walkthoughs
Hawkmoon36
I have a 600 frame walkthrough that I am getting ready to start and it needs to be done on high at least because it's for a presentation. I'm looking at a week's worth of work.
Fri, Nov 20, 2009 at 7:45:40 AM | multi level walkthoughs
Not sure what you mean.  I did a walk thru of a parking garage where I set the path to go up the ramp just like a car would.
Multi Level 3d into Single Level 3d
Thu, Jun 18, 2009 at 2:02:02 PM
Multi-level buildings
Tue, Feb 17, 2009 at 2:27:04 PM
Editing Multi-Level Building
Wed, Jul 20, 2011 at 11:11:04 AM
Walk through's on multi levels
Mon, Oct 3, 2011 at 10:32:00 AM
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Page generation time: 2.0615
