15 Users Online (14 Members):
Forums >> Community >> The Studio >> importing to viz or studio max 8 help??
i tried to import a revit file into viz render and it turned into poly lines..is there a quik way of changing this or preventing this from happening as i converted to a dwg file then took it to viz. not only does it change to poly lines but it runs twice as slow because of this. any hints or tips or anything would help because i want to try and render in viz-studio max with a original revit file because revit is much easier to work with although i like to use viz for rendering and fly bys to make comparisons on the rendering between both programs
thanks
you have to export a 3d view, and in viz you'll use the file link manager to bring in your DWG with the revit modell, set your presets to Revit, make shure you rescale .... in the tutorials of the help menu in VIZ there is a good tutorial of how to work with Revit files, I have found that I can work with all my building components like walls glacing frames etc to improve materials and continue working in the revit model and the two files stay linked until I bind the revit file in VIZ .... really cool conection between those two programs
oh excellent cause i was worried they dont work well thanks heaps for the reply i greatly appreciate it hehe now i can start exploring both programs more. also you said i need bring in a 3d view is it possible to still do fly bys with viz ...but il just read the tutoriakls and try learn for myself thanks for the tips..any others welcome thanks
I was also wondering if this was possible. Im so glad it can be done!
i solved my problem when saiving the 3d view as a dwg file its options were poly mesh instead of aic or something like that. hehe also would a revit model get the same out of viz as adt?
Importing from 3D Studio Max |
Fri, Jan 8, 2010 at 10:00:38 AM
3D Studio Max 7 data exchange problem |
Wed, Apr 20, 2005 at 2:29:13 AM
Exporting from Revit and into 3D Studio Max |
Wed, Oct 31, 2007 at 1:25:11 AM
3d Studio Max |
Wed, Apr 7, 2010 at 12:25:38 PM
Importing from 3DStudio Max |
Mon, Apr 18, 2011 at 2:04:03 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
