51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Material takeoff - the math doesn't jive
5 Posts No Rating |
Anyone had an issue with how Revit is calculating material areas when using the material schedule feature?
For example if I place the straight out of the box Fixed: 36" x 72" window to the project and then generate a Window Material Schedule for this one window I get the following results:
Glass - 30 SF
Sash - 56 SF
Simple math tells me 3' x 6' = 18 SF of some material max for that window size. I don't think Revit is multiplying wrong, I just really like to know what is using to get these numbers. Is it doing both sides, rough openings, adding in sill heigts or floor to floor elevations. Walls seem to work correctly, but windows have some weird Kung Fu associated with them.
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Material Takeoff issue |
Mon, Oct 25, 2010 at 3:48:35 PM
Ceiling Material Takeoff |
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff for insulation?? |
Mon, Oct 28, 2013 at 9:57:10 AM
Scheduling Curtain Panel in Material Takeoff |
Fri, Jun 1, 2012 at 2:47:52 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
