51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sloping paving slab?
Wed, Sep 6, 2006 at 7:13:10 PM | Sloping paving slab?
vnd
3 Stars: 2 Votes
How does one make a sloping paving slab, which starts at one height at the edge of the dwelling and slopes away from the house?
VND
Wed, Sep 6, 2006 at 7:25:31 PM | RE: Sloping paving slab?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
How complicated is the shape? Is it around all sides of the house or just a path off at one point? are there multiple slopes needed?
Wed, Sep 6, 2006 at 9:49:58 PM | RE: Sloping paving slab?
vnd
3 Stars: 2 Votes
Yes, goes round the entire dwelling and will need multiple slopes.
VND
Wed, Sep 6, 2006 at 10:21:55 PM | RE: Sloping paving slab?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like a job for an in-place family blend, coupled with a void to cut out the extent where the building slab is. I've used this method numerous times.
Sat, Apr 21, 2007 at 8:26:21 PM | Sloping paving slab?
cadjockey
Mr Spot,
Can this work around create a multiple gradient paved area? eg. a sloping diveway that slopes down in two directions from the garage floor slab. From the garage to the street as well as from left to right.
Also. will this show up in section the same way a floor slab that has been created using the floor tool?
cadjockey
Sun, Apr 22, 2007 at 6:30:27 PM | Sloping paving slab?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you have 2008 in your can now use the floor point edit tool to do this...  Much quicker and simpler.
Regards,
Chris.
Thickened Slab Edge on Sloping Slabs
Thu, Apr 16, 2009 at 3:39:09 PM
Multiple sloping slab on grade
Wed, Sep 28, 2005 at 11:20:28 PM
sloping slab
Tue, Mar 15, 2005 at 9:54:51 PM
Ramp / slab clean up at intersection
Wed, Dec 14, 2005 at 11:28:47 PM
Reinforcing a Sloped Slab - Please Help!!
Thu, Oct 1, 2009 at 5:43:32 PM
Page generation time: 0.5021
