65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Column Placement and Adjustment
Thu, Oct 7, 2004 at 12:34:38 PM | Column Placement and Adjustment
ClarTech
I recently downloaded a column model from RC, and placed it in my project. But I don't like the way it looks. Can I adjust the position of the features on the column (i.e. move a certain feature up or down) or adjust the thickness of it? I'd appreciate any help. Thanks -clartech
Thu, Oct 7, 2004 at 1:44:28 PM | RE: Column Placement and Adjustment
Mr GG
3.5 Stars: 9 Votes
Yes, you can. Have a look at the image. You have to open the .rfa-file with the column and select the column and click the Edit button. Now you can make changes. The parts that are dimensioned and have got a parmeter is a little more diffucult to change. Perhaps easiest is to delete them and then change them and dimension them again and give them a parameter. In a new reply I will send a .pdf-file with a tutorial on how to do a new family. I hope you understand a little more after completing it. This tutorial I made yesterday and I hope it soon can be find among the other tutorials on RevitCity. You are the first one to test it!
Thu, Oct 7, 2004 at 1:45:56 PM | RE: Column Placement and Adjustment
Mr GG
3.5 Stars: 9 Votes
Here is the tutorial. I hope you like it. If it is something you find hard to understand. You are welcome to comment on it.
Thu, Oct 7, 2004 at 2:29:13 PM | RE: Column Placement and Adjustment
Mr GG
3.5 Stars: 9 Votes
Some more tips! If you know what dimensions you want to have on the column in the project(the .rvt-file) You can do it a little easier. You can in the project file go to Modelling > Create and choose Column Then you click Solid and choose Revolve Now you can do click Set Work Plane and choose Pick a Plane and Pick some wall - you have to have a wall first... Now you can draw an Axis and then choose Line and make a profile of the column and some Lines to make it a closed path Then Finish Sketch - Finish Family And you have your column!!! you can copy it.... You can instead use the .rfa-file you downloaded from Revitcity and perhaps change the name of it before you begin. Open the .rfa-file in Revit Select the column - Click the Edit button and you can see Axes, closed profile Now you can delete the dimensioned paramtric parts And begin to do your own profile. Save it And in the .rvt-file go to Modelling > Component - click the Load button and load the .rfa-file
Fri, Oct 8, 2004 at 12:43:10 PM | RE: Column Placement and Adjustment
ClarTech
Save it
Of all the tips you gave me, this one helped me the most! Thanks a lot.
-ct
EDIT: ok, so apparently...this board doesn't support Vb code. Oh well.
Post edited on 2004-10-08 12:43:40
Craftsman Column Problems
Wed, Jun 25, 2014 at 2:16:07 PM
assigning top and base levels when inserting columns??
Thu, Dec 18, 2008 at 8:09:19 AM
turn off Auto-detect Adjustment of wood beams?
Tue, Sep 2, 2014 at 4:28:16 PM
Slanted Columns in Revit LT ??
Wed, Mar 13, 2013 at 8:28:20 AM
Trouble with wall & steel column intersection and joist placement.
Fri, Dec 16, 2011 at 9:34:12 AM
Page generation time: 0.4462
