Forums >> Revit Building >> Technical Support >> Wall absorbing column
7 Posts No Rating |
AHHH!!! How do I stop a wall 'absorbing' a column? For example: I have a grid of columns but when i draw a wall to join them... the columns just go inside the wall!
You can use structural columns instead of architectural columns OR you can just unjoin geometry.
Post edited on 2006-09-06 21:15:50
Edit the column family,
Go to Settings-->Family Category and Parameters and untick "automatically joins geometry with walls".
Then reload the family.
HTH.
Hi, I have a similar issue where the solid model to indicate cladding around a column is not appearing in plan. When I go to Settings -> "Family Categories & parameters", it is greyed out. Can anyone help? N.
1 Posts No Rating |
I'm having the same problem described in this thread, except I'm already using structural columns. The column displayed fine (over the wall), but then I joined a beam to the column, and suddenly the column disappeared into the wall.
6 Posts No Rating |
I too have the same issue with wall absorbing columns, i found out in this forum that this is an old issue but still unresolved (?)
23 Posts No Rating |
i am using revit 2013 ...i have the same problem ........ unjoining geometry sometimes works and sometimes it doesnt . i dont know why . see the attached pic ....
please if anyone figured out the solution for this please post .... thanks
Did you read the full thread? Architectural columns are different that structural columns. What are you using?
What is your detail level?
these are unjoined architectural columns ... the detail level is set to fine ... i know there is a deference between architectural and structural columns .. but what if i want to use architectural column and i want to cut it from the walls !!
Here is my stock architectural column (2013) placed in different locations and my family's properties. What are yours? Obviously different than the stock.
what do u mean by stock !
Stock vs special .... the one that comes with Revit.... not one you created or loaded from somewhere else....
WHAT ARE YOUR FAMILY SETTINGS? Look at mine.- the right image.
ok see the 2 attached pics.... theses are my architectural columns ,,
