92 Users Online (91 Members):
Forums >> Community >> The Studio >> walls
1 Posts No Rating |
how do you resize the walls
width? height? shape? thickness?
29 Posts No Rating |
there should be an option for the setting if you are using a pre made wall type. if you make or modify an existing wall type you modify it changing the way the is built material wise such as the wall being made with an 3.625" stud and two layers of .625" gyp for a 2 hour wall. You can do this by clicking properties then clicking edit and clicking edit again
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
Members: | 2057421 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
