Forums >> Revit Building >> Technical Support >> Revit ---> Photoshop
7 Posts No Rating |
Ello. Wondering what the best way of exporting (or moving) a revit plan, elevation, perspective etc to photoshop with best quality? ...ie. Not too much pixelation in the lines...
6 Posts No Rating |
I'd print to a pdf...as long as raster format is acceptable to you.
i'd use
file
export image
i find it gives the best results
39 Posts No Rating |
this is my question too. i dont want to print anything directly from a sheet layout in revit. i want to export my building to photoshop so i can do some edits there. i am not just referring to 3D renderings but also 2D plans and sections. i want to export all of them to photoshop to do some edits. what is a good way to do that? what is a better format to edit in photoshop, PDF or TIFF?
Why don't you try both of them (PDF - TIFF), THEN post here about, what do you think the best was....
![coreed Avatar](user_avatar/14568.jpg)
i find that if is linework (2d) then printing pdf seems to give better line quality when opened in Photoshop. if is rendering images pic your format. i always print to pdf anything from Revit that i want to take into Photoshop.
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Yeah, I agree with coreed...in my experience I've gotten better results when I print to .pdf a Revit 2D or 3D view, (also when I print to .pdf a plan view, elevations,etc, from ACAD), then in photoshop when i've finished my image, I save it as .jpge file .....
Edited on: Sun, Mar 22, 2009 at 1:12:40 PM
but when we open a revit exported .pdf file (be it plans, sections, elevations) in photoshop, the entire image (be it plans, sections, elevations) tends to become lighter as compared to when viewed on opening the pdf directly. Even there is unsurity as the plots sometimes are decent and sometimes aren't.
revit into photoshop to scale |
Thu, Jul 19, 2012 at 12:37:09 AM
Revit to PhotoShop |
Thu, Jan 11, 2007 at 7:08:31 PM
REVIT AND PHOTOSHOP |
Thu, Nov 30, 2006 at 2:15:56 PM
exporting from Revit with a Photoshop destination |
Thu, Aug 3, 2006 at 6:27:55 PM
Revit to Photoshop |
Wed, May 4, 2005 at 6:41:48 PM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
