74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dimension graphical convensions
Wed, Aug 30, 2006 at 3:38:25 PM | dimension graphical convensions
kesflower
3.5 Stars: 11 Votes
Is there any way to change the graphic convensions of my dimensions? I get that I can change how accurate they are (nearest 1/2 inch or nearest 1/4 inch, etc.). But is there any way to change how many spaces there are between the individual numbers in the dims? For instance, 1' - 1 1/2" Is there any way to make it more condensed so that a lot of small dimensions are easier to read? Thanks for any help.
Wed, Aug 30, 2006 at 4:02:47 PM | RE: dimension graphical convensions
gdoorn
1 Stars: 1 Votes
create a dimension style text that has a tighter width factor. we typically use arial at 0.85 to save some horizontal space. you could make it tighter if you wanted. but it will do it for all dim text. there may be other ways, but i dont know of any.
Graphical Column Schedule
Mon, Dec 10, 2018 at 5:58:55 AM
Graphical Column Schedule Fields
Thu, Nov 5, 2009 at 10:30:02 AM
Base Plates & Graphical Column Schedules
Mon, Feb 22, 2010 at 11:51:01 AM
Graphical column schedule issues (Revit Structure)
Thu, Apr 24, 2014 at 3:24:33 PM
Graphical Column Schedule - Formatting
Tue, Jan 9, 2007 at 12:57:38 PM
Page generation time: 0.2871
