Forums >> Community >> The Studio >> Window sizes
Mon, Aug 28, 2006 at 7:20:32 PM | Window sizes
rudyard
1 Stars: 1 Votes
Is there a way to adjust window sizes of an existing window family? I have placed windows, but they only have certain sizes......do I have to literally build a new window family for each window size as the property to adjust the width and height is greyed out. E.g. If I have a sliding window and the sizes are 900,1200,1500 and I just want to make the same window become 1800 I cant do it as the option is greyed out. Coming from ADT where I can just type the width and height I thought it would be similar but apparently not??
Tue, Aug 29, 2006 at 1:50:26 AM | RE: Window sizes
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Easy Option 1 - In current project Select the window, click the properties button, then click edit / new, then click duplcate, then give it a name with the new sizes, then change the actual sizes in the properties for width, height, then ok, ok, ok. Option 2 - For future Projects You can also select the window, then click Edit Family, then ok. Once in the familiy editor click Family Types on the left and then add many new sizes via the Family Types Dialog box.. After your are done Apply and save the revised family file and then Load into Project to push it out to the open projects. There are lots of free and purchacable REVIT tutorials including detailed Family tutorials at http://www.dgcad.com
Tue, Aug 29, 2006 at 2:07:39 AM | RE: Window sizes
rudyard
1 Stars: 1 Votes
Thankyou....I will try it out and see how it goes.
multipanel window with variable sizes
Wed, Apr 20, 2005 at 9:10:11 AM
11
Help wanted! Window size issues
Thu, Sep 17, 2009 at 3:25:59 PM
Video Tutorial on creating a Window Tag that shows the Size rather than the Mark
Fri, Mar 10, 2006 at 7:59:46 PM
oval/ellipse window
Mon, Jan 3, 2011 at 5:48:11 PM
How to add sizes to Windows on floor plan?
Wed, Dec 16, 2015 at 6:19:19 PM
Page generation time: 1.2134
