44 Users Online (42 Members):
Forums >> Community >> The Studio >> Floors - Constant-height-defining lines must be parallel??
Am trying to learn revit 8.1 and have become stuck when trying to add a floor.
I have a 2 storey house and it is the first floor, 300mm timber - revit has a generic 300mm floor which im using.
However I select the walls of the first floor (they do not sit exactly over ground floor walls) and when I finish the sketch I get the error message 'Constant-height-defining lines must be parallel'
I change everything I can find in the properties but I just cant seem to get rid of this message.
Im totally stuck, does anyone know the property setting I have wrong so I can add a simple floor??
Have you first defined the level at which you want the floor to be at? For exampleif your floor is at Level 1 - go to the floor plan of this level and then either select walls or sketch lines to draw the floor. .
Deb |
"Have you first defined the level at which you want the floor to be at? For exampleif your floor is at Level 1 - go to the floor plan of this level and then either select walls or sketch lines to draw the floor. ."
Tried that but it doesnt seem to work. I just cannot get rid of this message. Does anyone know what it actually means?? I am at a loss.
I would attach the file but all my revit files seem to be massive (9mb with not much in the drawing).
rail on ramp with constant height bracket? |
Fri, Jan 8, 2010 at 1:52:17 PM
NEED HELP ASAP ON CEILING! |
Thu, Apr 26, 2007 at 5:18:14 PM
Dimensioning 2 non-parallel reference lines |
Thu, Feb 14, 2008 at 9:40:47 AM
Dual Sloped Floor without Modifying Sub Elements |
Sun, Dec 29, 2013 at 10:41:27 AM
Mass Floors with a Minimum Height/Clearance |
Wed, Apr 18, 2012 at 5:25:50 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
