58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> quickly changing line weights
Mon, Aug 28, 2006 at 9:44:44 AM | quickly changing line weights
sweetiedarling
I was wondering if there were some way to have multiple line weight settings, similar to the way Autocad allowed different CTB printing files. I'm finding that I need to tweak lineweights slighty for a presentation plan vs. a working drawing plan. They are the same scale. The only way I can think of doing is resetting the lineweights for the 1/8" scale plan, and then changing them back to continue printing my working drawings. Any suggestions?
Mon, Aug 28, 2006 at 5:50:55 PM | RE: quickly changing line weights
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
One method would be to use Advanced Model Graphics and turn on Override Silhouttes in the plan. Then you can adjust the lineweight for silhoutte edges. Alternatively I would give overrides in the visiblity settings for each object style then save it off as a presentation plan view template. HTH.
Tue, Aug 29, 2006 at 3:30:51 PM | RE: quickly changing line weights
sweetiedarling
That worked, thank you!
Fri, Apr 13, 2007 at 2:56:08 PM | quickly changing line weights
RSquared
is there any way to set surface patterns to half tone?  it seems there is not an opportunity to do so.  i am having problems with my printer interface by changing the color of the pattern
Changing line weights in a single drawing?
Thu, Apr 8, 2010 at 9:01:02 PM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Any ideas on modifiying lineweights
Tue, Nov 13, 2007 at 7:59:39 AM
Page generation time: 1.0420
