23 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> please help #2
9 Posts No Rating |
if you use the if formulaif ( height>3000metres....) how do you know what part of the formula refers to what in the parameter? the depth or the width?
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
hi there if statements work as follows.
If(Condition,True,False)
Condition - This part is for you to control the if formula. In you example you would be saying that if the height is larger than 3000m.
True - This is what you want to happen if your condition has been met.. So in other words if your Height is larger than 3000m then I want it to be 3000m.
False - This happens when you condition hasn't been met. So I would say that if it is smaller than 3000m then I want it to be Height.
9 Posts No Rating |
thanks so much ![Smile](/images/smiles/smile.gif)
Members: | 2025973 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
