Forums >> Revit Building >> Technical Support >> ray trace
3 Posts No Rating |
how can we speed up ray trace?
it takes more than half an hour for a presentation ray trace!
only 1/2 hour??
you can lower the Radiosity a bit but this will effect your final image, you can also "Set the value in the spin box for Solution Goal. This limits the radiosity calculation to a certain number of steps. This value is used both for the initial number of steps when you first use the Radiate command and for any subsequent calculation by clicking Continue from the Options Bar."
a better cpu maybe, though Revit is not yet taking advantage of dual core, but a fast CPU will help, since all the calculations are done there... ram and video card won't really effect rendering time.
Correction, Revit does take advantage of dual processors when rendering only.
hmmm, didn't think dual core made it to Revit... I know for sure they are working on a dual core for 10...
it's not like Autodesk told us that revit supports OpenGL, is it??
It's been there since version 8.1 at least.
Accurender is far more dependant on your processer than your graphics so it stands to reason that the better your processer the better your rendering whereas other rendering products tend to allow for graphics cards.
Ray trace Disabled in Revit 2013 |
Thu, Apr 4, 2013 at 5:47:34 AM
Cut pattern override |
Wed, Dec 4, 2013 at 10:41:30 AM
Ray Trace Images - Save without surrounding screen area? |
Wed, Feb 5, 2020 at 1:37:10 AM
gbxml export for Trane Trace |
Tue, Jul 26, 2011 at 7:14:55 AM
REVIT TO TRANE TRACE |
Thu, Mar 14, 2013 at 8:27:15 AM
Members: | 2115570 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
