77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to insert RPC objects other than RealPeople into Revit?
Tue, Oct 5, 2004 at 8:22:04 PM | How to insert RPC objects other than RealPeople into Revit?
samlam
Can we use other RPC objects like Cars, Chair, Trees etc.... in Revit? Can we use the Metric RPC template to create the above families in Revit?
Tue, Oct 5, 2004 at 10:45:52 PM | RE: How to insert RPC objects other than RealPeople into Revit?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Certainly can, however the new rpc files don't work. It all depends on the version of the rpc object...
Tue, Oct 5, 2004 at 11:38:06 PM | RE: How to insert RPC objects other than RealPeople into Revit?
samlam
How do I know which version allows me to edit?
Wed, Oct 6, 2004 at 4:50:25 AM | RE: How to insert RPC objects other than RealPeople into Revit?
Mr GG
3.5 Stars: 9 Votes
Archvision - the RPC folks - does not write very much of diifferent versions I Googled for: RPC-2 RPC-3 Rich Photorealistic Content and found this adress from the japanes distributor http://www.applicraft.com/rpc/RPCPlugIns.html And this one: http://www.archvision.com/RPCPlugIns.cfm On this adress you can see that Revit does not support RPC 3 but Accurender support RPC 3 More explanations I have not found What is the difference between RPC 2 and RPC 3 ???? Here is something else... It is a guy who has written scripts for RPC and 3DS Perhaps they - the scripts - can do it in Revit but I do not think so http://www.3idee.nl/3d/html/layout.php
Rpc object and Revit
Wed, Mar 31, 2004 at 5:13:09 AM
Black square behind RPC Objects
Fri, Jul 20, 2007 at 2:49:34 PM
RPC Objects
Tue, Sep 7, 2010 at 3:04:36 PM
convert RPC objects to revit
Sun, Oct 26, 2008 at 2:59:00 PM
RPC objects wanted
Sun, Oct 26, 2008 at 3:00:23 PM
Page generation time: 8.2819
