Forums >> Revit Structure >> Technical Support >> Can Ram steel model be used in revit structure
8 Posts No Rating |
and how?
if you can save it as a dwg, dgn or acis... but it won't retain any parametric properties, it will come as a one solid model
2 Posts No Rating |
RAM steel model can be used in revit structure, but the model has to be created in Revit Structure first, then exported to RAM. RAM will design the members, and then the RAM model can be read back into Revit Structure. I'm not able to get all the members from Revit to RAM. For instance, the bracing I model in Revit does not read into RAM. But, the columns and beams translate correctly. Haven't tried foundations, yet.
2 Posts No Rating |
Has anyone had the problem where you have RAM installed on your machince and you are not getting the tools>external tools>send model to..... I am not even getting the option to send the model out to RAM, anyone know why this would be? thanks in advance
----------------------------------- Kev
Structural CAD |
Keep in mind that Bentley owns RAM Sys. and they are the ones that are designing the link betweent the two programs and not Autodesk. At this point in time, RAM is probably the closest to a two way street between a structural bim program and an analysis program (though RAM is more than that.) There are some issues with the link, but if the model was done in Revit first, they do have a prety good link up. However, Autodesk is aquiring Robobat, the makers of Robot Millennium, out of France. Since this is going to be Autodesk's software, I see them spending a lot of time and money to make this the best possible choice for a link between Revit Structures and an external analysis program. It is current available for download from Robobat's website. As fo the option not showing under the tools menu, I would check to see if you have the latest link from RAM. You should be able to download from their web site. Then just load it into Revit Structures. (should come with directions) Hope this was helpful, Brett
2 Posts No Rating |
To get the link to show in the external tools you may need to edit the Revit.ini file. Open this file and check that the ECName#, ECClassName#, ECAssembly#, and ECDescription# are unique. You may have to renumber them to the next available number. Also, check the ECCount = #. You may have to increase this number as well.
Ram steel model into revit structure |
Fri, Sep 1, 2006 at 8:04:46 AM
TOP OF STEEL / RAM IMPORT |
Fri, Jun 6, 2008 at 1:32:42 AM
RAM Model to Revit Structure 2012 |
Thu, Dec 1, 2011 at 5:37:10 AM
Revit Arch importing RAM steel files |
Mon, Jul 16, 2007 at 9:01:20 AM
Ram Structure imports |
Thu, May 31, 2007 at 1:17:15 PM
Members: | 2115021 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
