69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> SPLIT REGIONS
Wed, Aug 23, 2006 at 9:10:15 AM | SPLIT REGIONS
moxierawk
Instead of using the subregion tool, I have been using the Split region tool to split between the road, curb, and grass. The only problem is that when i move the curb region up about 6" there is an open gap between the road and the curb. Is there any way to create a loft between these two region to represent the curb better, or is there a better way to do this in general.
Thu, Aug 24, 2006 at 9:45:41 PM | RE: SPLIT REGIONS
TomDorner
4.5 Stars: 25 Votes
The short answer is no. Doing site work in Revit is very difficult and generally I avoid it except for context to be used in a rendering. Then I try to keep things very flat or with a regular slope. For your situation you might try some of the curb site components which will follow gentle splopes but even then not perfect. I have also used walls with edited profiles or attached to reference planes to act as curbs. A search of this site or out at www.augi.com may yield more indepth methods other use. HTH Tom
Thu, Feb 11, 2010 at 12:16:10 PM | SPLIT REGIONS
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I know this post is old - but with the new Revit versions, try this:
http://bimtionary.blogspot.com/2010/02/curb-and-gutter-along-topo.html
cad.web.print
Scheduling cut and fill when using split regions
Sun, Sep 21, 2008 at 8:56:59 AM
Splitting wall Regions
Tue, Jan 27, 2009 at 10:16:19 AM
Walls, Split regions and Materials
Fri, Jan 20, 2006 at 3:13:13 PM
Graded Region from split surfaces
Fri, Feb 1, 2013 at 8:36:28 AM
editing split face boundaries
Wed, Jun 4, 2008 at 9:43:19 AM
12
Page generation time: 7.8408
