46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Customizing Titleblocks
11 Posts No Rating |
How does one change the standard titleblock?
We have the Standard "Autodesk Revit" title and would like to Customize it on a current project already in production. Can we do it without restarting the entire project?
Prehaps what you are looking at is to create new titleblock family and reload it/ them into your project. remember to use label for items which got fields to key in or inter-link such as scale, sheet no, drawing title etc.
You can create a templete for your titleblocks and all sort of standard family by creating templete file. After you create a templete file, you just drag and drop it to your revit icon in desktop and the new revit project will start up by all the preset templete family including titleblocks
You could also open the current revit metric titleblock and edit it to suit your needs. might also be a good idea to understand how the titleblock is created...
2 Posts No Rating |
Along these lines, Our office is currently converting to Revit from AutoCAD and I am having trouble with inserting our title blocks into a new titleblock family. For some reason, everytime I try to insert our DWG titleblock into the new Titleblock, Revit tells me that some items won't be visable and that I should explode the DWG and set proxy graphics to 1. Both of which I have tried with no success. Some time last week I managed to successfully get one title block set up, but I don't seem to be having the same luck this time.
What is the best way to get DWG information into a new title block without redrawing everything from scratch? Any guidance would be appreciated.
Customizing Families and objects |
Wed, Oct 26, 2005 at 4:07:45 PM
TitleBlocks |
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options |
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks? |
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks |
Mon, Mar 17, 2008 at 3:03:10 PM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
