54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do you hide the joint lines between different wall types?
Mon, Aug 21, 2006 at 10:20:04 AM | How do you hide the joint lines between different wall types?
Motorcity
4 Stars: 2 Votes
Using similar multiple stacked wall types in the same plane but we get a line at each wall joint (see image). How do we hide these joint lines in 3D and elevations?
Motorcity Job Captain VOA Associates, Inc.
Mon, Aug 21, 2006 at 10:53:11 AM | RE: How do you hide the joint lines between different wall types?
jreviteer
You can try using Join Geometry tool to join all those walls. As soon as they are joined, the lines will disappeared.
Mon, Aug 21, 2006 at 12:10:59 PM | RE: How do you hide the joint lines between different wall types?
Zenoza
You can also try to use only one wall. Place the two different window type's. With split surface you can ad a different hatch surface pattern and material to the wall parts above the windows
Mon, Aug 21, 2006 at 12:12:17 PM | RE: How do you hide the joint lines between different wall types?
Motorcity
4 Stars: 2 Votes
That's the one, thanks! That's the command I was trying to use but the problem was that the walls did not actually meet. If you zoomed in really, really close then, you could see it. Thanks again!
Mon, Aug 21, 2006 at 3:10:28 PM | RE: How do you hide the joint lines between different wall types?
gdoorn
1 Stars: 1 Votes
and for future reference...be sure the 2 walls align. i struggled with that one day for a half hour. my walls were slightly offset and it couldnt be detected from normal magnification.
Wed, Sep 6, 2006 at 3:42:01 PM | RE:
Perry
Quoting Motorcity - 2006-08-21 12:12:17
"That's the one, thanks! That's the command I was trying to use but the problem was that the walls did not actually meet. If you zoomed in really, really close then, you could see it. Thanks again!"
Motorcity, I tried to call your work number today. But with only an internet nickname, I couldn't get through. Please call me or send me an email.
Post edited on 2006-09-12 12:41:20
Mon, Sep 11, 2006 at 9:56:04 AM | RE: How do you hide the joint lines between different wall types?
Motorcity
4 Stars: 2 Votes
O.K. Check your e-mail!
Tue, Sep 12, 2006 at 11:22:58 AM | RE: How do you hide the joint lines between different wall types?
derxaj
3.5 Stars: 3 Votes
I had a wall once that wouldn't join no matter what I did...align, redraw it, everything it wouldn't work...I'm sure it was something I did wrong but I couldn't figure it out...so what I did was use the handy little linework type tool and set those lines to invisible. If you have a problem like that and you don't want to waste the day trying to figure it out (which most firms can't afford) then use to the linework tool...it works wonders... Adam
Fri, Nov 16, 2007 at 8:16:34 AM | How do you hide the joint lines between different wall types?
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Go to property, edit, defaul wrapping. play with at insert & at ends, this works.
How do you hide different material joint lines?
Thu, Sep 15, 2011 at 6:53:41 AM
Hide joint lines in 3D and elevations
Thu, Sep 6, 2012 at 4:08:47 PM
Creating joint lines!!??
Mon, Mar 27, 2006 at 10:59:33 AM
Phasing: problem with new doors in existing wall joint lines
Mon, Sep 19, 2011 at 4:32:08 PM
Hide elements in family by types
Thu, Sep 5, 2013 at 10:19:11 AM
Page generation time: 1.2448
