39 Users Online (37 Members):
Forums >> Community >> The Studio >> SCALE
11 Posts No Rating |
do you know how to resize a site?i made a side(as undependent file) smaller then main drawing which is a building.Is it possible to resize all elements(toposurface,subregions,etc...) or put the file(site) by importing and resize?
plese HELP!
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
once the drawings is imported, you can click on it and select the "scale" tool from the top right area... you have numerical scal and, the one you want, graphical scale.
click on one end of a line, click on the end of that line and than click on the final length your line should be.
the first 2 clicks tell Revit how long is youe line the third click tells Revit how bigger you need to make it.
hope this helps, remember F1 is your friend
if it's an Acad drawings, might be more accurate to do it in Autocad...
tx for help!
but I cant check, because my file is corrupted.I don't know what happend but I send it to the Autodesk.
I will build example-terrain and i'll check it.But I think I tried to do this and the Resize icon was not active.
I will check it one more time
TX
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
scale image |
Fri, May 13, 2016 at 1:11:44 PM
Scale Bar Link To Titlesheet Scale. |
Thu, May 23, 2013 at 6:36:16 PM
scale check |
Tue, Oct 23, 2012 at 5:05:08 AM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
